I just baught a American bass Amp, its an older model ( like an 02) i think its about a 600wt, im not sure..it dont say on it.. it carrys a 40amp fuse, i got it connected to a sony xplod 12'' 900wt...(the older ugly type) My problem is every time i switch a track or station the amp goes on to protection , i checked all the wireing..its next to perfect.. i got a 60amp fuse coming off the battery to the amp, i used 4gauge wire, for the ground and power, i checked the power level coming from the remote wire and the power wire...there both 12vts.. The the entire system sounds great except the turning off part... the only way to get it back on is restart my car or disconnect and reconnect the signal wire. The signal wire is coming from the deck..and the deck is a older panasonic....
anywase..id appreciate it for some advice.
