1 - 8 of 8 Posts
Hi,
This may be a dumb question but i'm gonna ask it anyways.
I am looking in purchasing the jspec ecu to go with my klze. My car is mtx, is it ok to buy an atx jspec ecu? are there any differences?
Thanks for your help guys.
RObbie
I'm no expert, but for what the ECU does, I don't think it makes a difference on the transmission. If you want to verify this quickly, do a search for the ATX to MTX conversion threads. Look for mention of the ECU there. If nobody else is changing the ECU going from ATX to MTX, I'd say you're fine.
Yep, I'm using an ATX ECU (KL-36) with my KLZE/MTX ... the MTX ECU code is KL-31, for information purposes ... (open to correction) ...
I have a problem. I have a 1994 mx6 v6 manual transmission, somebody stole the ecu motor serial kl374646 chasis JMZGE16F2012*****. What ecu should i buy? Works kl01 ir kl03?
Late reply, but
93 MX6 V6 KL01 can use but your rad fans will run constantly due to a missing sensor on 94+
KL03
94 PGTv6 KL55
93 PGT v6 KL07 can use but your rad fans will run constantly due to a missing sensor on 94+
There is a post somewhere that lists all the ECU models and the year make and transmission type
1 - 8 of 8 Posts
