-----for those of you with your motors together where is the wire that clips into EGR valve
----- theres one connetor that seems to start at the of oil filter where does this one go?
:shrug:
wire with a fork in it or an actual plastic connector?
I believe the knock sensor plugs into your harness near the EGR. The wire with the fork in it goes to the sensor in the rear top of your block. located above your oil filter slightly right if you underneath. Good luck getting that on without removing anything! I did it but it was very frustrating.
