1 - 12 of 12 Posts
Is there supposed to be any play with the stock endlinks? On my 88GT, hen the car is flat on the ground I can move mine up and down a little. On the 92GT I can move them up and down a lot... I am hoping that replacing the endlinks on the 92 will help with the suspension a lot, otherwise I will need struts sooner.
Nope there shouldn't be any play. You should really get the Addco endlinks, sizes 12 and 15 (15 on back). They are really great and cheap too.
Already have the new ones, just wanted to make sure. My issue on the 88 is that I will be lowering it soon (1 inch drop) and wanted to make sure that the 12's and 15's will still fit properly.
I had no problem with mine.
what are endlinks?
What are endlinks, i've never heard of them, but i read that they made "a world of differece." Hopefully i'm getting some intrax springs soon, will the endlinks add to the handling?
The endlinks, or "sway bar endlinks" are what attaches your sway bar to the control arms. The Addco endlinks bushings are made out of a thick, stiff polyurethane which really amplifies the affect of the sway bar. The benefits are flatter cornering, and more responsiveness.
Sure they'll work just as wonderfully on the 2ndgen as well. However, the 2ndgen uses different endlinks. I've heard that the endlinks from a Nissan altima fit, but I'm not sure if that would be like stock replacement, or a performance replacement. I think you should post in the 2ndgen forum about it. They'll know more.
1 - 12 of 12 Posts
