I ran the engine diagnostic test according to "http://home.golden.net/~trinity/malf/malfcode.htm" on My 94LS. the car have less engine power lately.
the Check Engine Light returns 3 blinks, stop for a few seconds and gives 3 blinks.. and it repeats.
Does this mean I have error code 03?
Code 3: G Crankshaft Position Sensor Failure ?
just want to makesure with one of you guys.
thanx.
Yes, that sounds like a code 03 - G sensor. When the light is on (i.e. the PCM isn't getting signals from the sensor), you'll notice that the engine runs rougher, has less power and a crappy idle.
The most likely culprit is the igniter module in the distributor. Before replacing it though, double check all wiring connections to the distributor; make sure they're all clean and the connections are solid.
