hey all, we blew the gearbox in the tx5 and decided to recon the engine at the same time. so all engine mounts are stuffed (rubber cracked) is there a solution to paying $130 for each one besides leaving them? we get the call tomorrow that will tell us whether or not the g/box is repairable. its a 2.2NA so it shouldnt be as hard to find as a F2t box.
Thanks.
Thanks.
try sika flex n dem
http://www.mx6.com/forums/showthread.php?t=119819&highlight=sika
Thanks, so which product should I use?
its for a 2.2NA Manual, All mounts cracked.
PS ill need to spread some rep mrmx6
i need all of the mounths.
also i think its $1300 to recon the box but ours needs some cog because its stripped. If its unrepairable we will be getting one from adelaide jap for $750.
hey flav, where did you get your extractors? how easy to install?
and thirdly will you weld them up for us :D
i need all of the mounts.
