Engine replacement
881 Views 9 Replies 6 Participants Last post by  rebelz99
He all, first time posting, I no there are a lot of debates on the klze engines, but I would like a quick and honest answer. The car is an everyday driver so I need it fast....
Issue on the de is possibly the piston rings (way to expensive to fix), uses 1qt of oil at every gas fillup....
Now I ain't interested in slapping in a scrap yard engine at 500$ so I was looking at the KLZE engines.
I've got a 96 LS man. (OBD II) stock... Rigth now I don't care about performance (I just want it about the same as stock de. I don't have the time or money to do a complete swap...
What I wan't to know is will I be able to swap an OBD II car with the KLZE engine (keep in mind that I am keeping everything ecu, harness...) and having a reliable car...
Would I need to expect any issue's as for fitment and any mechanical pieces to be change except the engine harness...
Don't want any MS, I want to keep everything orig. for now and maybe this spring I will complete the swap...
Anyone know of a good place to buy a klze in montreal
thks, rebz
1 - 10 of 10 Posts
Aside from checking out local import yards and such, I'd just buy online.
I've read that putting the ZE in an OBII Mx-6 is a pain, but I've yet to hear or read why. If you're not caring about performance, I'm sure you could pick up a DE online easily too. The ZE I don't think would take THAT much longer to swap. Just rerouting the vacuum lines, and it should still run on the OBII ECU, just not to it's full potential. Probinator offers a chip, I know, as well as a few other people I'm sure off, that could solve this. Shouldn't be too long to install a chip, but I don't know much about that, I'm no electrician, or annything even close. :tdown:
The only other thing would be sealing off all EGR stuff on the exhaust if you stuck with the stock exhaust.
But if it's more than you want to deal with, I'd be looking at buying a DE perhaps off here from someone who just got a ZE or whatnot, or searching offline. But the ZE should run off everything stock, just not at it's best. Depends on if you deal with the exhaust so you don't have any holes in it, ect...
Oh, and you'd need an aftermarket intake. Could just throw a cone filter on your VAF though...
Anything I missed out, or you want me to talk more of?
I'll try to help as much as I can, but I haven't messed with anything of the such yet. So I can only point you, lol...
Hate to say it, you can probably pick up another v-6 mx6 for the price of getting a ze into your current ride.
Not if he's doing it himself. Besides, a new MX6 means a new set of problems, and a lot of the maintenance for a new engine can be done while the engine is out of the car. Best bet is to just get another DE if you don't care about performance, those will be much easier to find than a ZE and you won't run into any harness or emissions problems.
Even if a mechanic installs it, total price should be less than $1500. I think $1500 is around where mx6s with few mechanical problems start.
Thks for the replies, I've got a co-worker who's brother is fed up of his sons project. He's tired of putting money on the car so he's selling the car, it's a 94 ls with aut trans. with all the klze gooddies. He blew the trans, so if the price is rigth and the engine runs well, i'm picking it up tommorrow... Now the desicion is if I swap everything on my 96 body or if I slap in the man trans and cluth on the 94 body....
Does the ECU work on any transmission or is it different for atx/mtx.... The ecu ain't chipped, i've got excellent soldering skills, is it something I can do or it needs to be reflashed... Also is it possible to flash an OBD II ecu to work for since I would like to use the car while it's worked on...
is the megasquirt used only on unmoddified ecu's or is the ms essential for all ze setup
it's much easier to swap in a different engine than it is to swap in a different transmission and change it from auto to manual. Auto and manual have different ECUs, and to run a ZE the stock ASpec ECU will be fine, although you won't get all the power out of the engine. You would need the probinator chip, a KLZE ECU, an ECU from xtremethings, or any other ECU with the correct VRIS points. The ECU is all you need, not megasquirt
I beg to differ... Aside from squeezing yourself in the driver's area to install pedals, swapping atx-mtx is way easier than a motor swap. The atx ecu is just fine to use with the mtx setup. OP, if you're still contemplating what to do, swap your tranny onto the klze. I mean, if you're going to swap the motors, why not. You'll have to drop the auto out the bottom before pulling the klze out anyways, unless you can contort the motor with atx attached and get it out. Then just pull your motor with mtx attached, take off the tranny, and put it on the klze. Sounds easy? It is really, just time consuming and sometimes a pita, just have patience and it will be fine. :cool:
Well I will tell you swapping the MTX into an ATX car is no picnic. I could give you a laundry list of stuff you will need to complete the swap. Infact the thread is here:
http://www.mx6.com/forums/2g-faq-pe...nsmission-swap-2-5-v6-parts-1-2-complete.html
BUT...IMO putting a ZE into an ATX MX6 is a HUGE waste of time and money. My old DE engine I had would bounce of the rev limiter for like 2 seconds before my ATX tranny finally shifted and it was a ROUGH shift, but I found it hilarious. Probably a reason why your buddies ATX blew, our ATX trannys are CRAP. I could probably put it on a firefly and blow it up LOL. Best thing I ever did and most people will agree, putting an MTX with a KLZE is the best thing you can do if your gonna do the swap. I mean look around the forums, how many ZE powered 6's do you see with an ATX in it?
As for the ECU, YES there is a difference between the ATX and MTX ECU's. When my car was in the shop for the first stint the mechanic mentioned he had left the ATX ECU in the car but when he got over 70 KPH, the car would cut the fuel and die. Our guess was it was a safety measure. So you will want a MTX ECU.
Now dropping it onto an OBD II chassis. Well IMO all it shows is how well you can jerry rig. The KLZE engine was not OBD II, if memory serves it is not an easy task to perform. There are about 100 threads on how to do it, but I can quickly summarize.
1) You will need the 2 MSD window switches and an adjustable fuel pres regulator to control the VRIS solenoids and fuel curves.
2) As for the EGR, most people block it off and deal with the code. It is not a direct swap. This thread explains how to install an EGR onto a ZE manifold.
http://www.mx6.com/forums/2g-faq-performance/77781-klze-intake-manifold-im-installation-guide.html
Confirm this will work though as the writeup was made for hooking up an EGR to a ZE manifold going onto a DE. Personally if your not worried about emissions and the CEL than no need to worry about the EGR, just make sure all the holes are plugged in the exhaust.
To my knowledge I have not heard of anyway to flash or chip an OBD 2 ECU to work perfectly with the ZE. Probinator's chip does NOT work on OBD 2 cars, only OBD 1.
Personally I would rather have a ZE on an OBD 1 car and without question on an MTX 6. Most will agree with that.
but it's your choice, but dont be afraid to put a little work into her, your labour will pay off ;)
Actually it's not that bad... I actually had a picnic (ate a sandwich while under the car! lol)
Yeah, you do need alot of things to swap, but you do remember he has an mtx 6. So he has access to all the swap parts he needs...
Well I'm actually not going towards the ze engine, not comfortable with it... I believe that they are overrated on the 6ers....
I'm getting an old v6 rebuilt, everything new (water pump, oil pump, all gaskets) oversizing it to 0.04, repainted with a 1 year/25000 km warrenty....
All this for 1500.00....
I don't need a car that reaches speeds of 250km, I just want one that has good, very good acceleration......
I'm a truck owner and I prefer torque over hp.......
1 - 10 of 10 Posts
