I own a 95' MX-6. When I idle in gear the car starts to shake. If I put it in nutral then it idles perfectly...no shaking. Sometimes the shaking is almost embarrasing if I have people in the car. Does this happen to anyone else? Any suggestions for help? Thanks...
Is the engine shaking vigorously when its idling? What's the idle up to when it starts shaking? Does it feel lke it's about to stall? If so then you can adjust the throddle body so that you can idle a little higher. If the engine is still dhakes then the only thing that I can think of is the engine mounts.
I never really had this problem so I never researched it. I'm sure you'll get other better opinions in time.
My car does that to some extent and i just had the fuel injection and throttle body cleaned at the dealership, it could be motor mounts i'm trying to find out why mine does it to so if i find out i'll post it on here for you to see, is your car automatic i assume? and is it a v6 or 4 banger?
mines a 4 banger
