Yep, but...
xvsxevx said:
Can anyone tell me if it's possible to drop a V6 2.5L in my current 2.0L MX-6?
Sure. The 2.5L engine was installed at Flint Rock in the same chassis, so it's easily possible.
Mounting-wise, it shouldn't be too bad, though you might want to check if the lower cross member is the same. Axle shafts are most likely different as are the front springs.
Electrically, you're in for a challenge. The two engines use completely different engine control computers and their harnesses are (obviously) not interchangable. It'd be alot of cutting and pasting to get it working right.
I know you've probably heard this before, but considering the amount of work required to do the 4-6 swap, why not consider selling your MX-6 and looking for an LS to replace it with?
