What might be the problem if:
after several miles on the hwy, then, slowing to a stop, the temporature on my gauge moves past the mid-range approaching hot, then, it goes back down...but a little higher than normal (the car does not overheat). Any thoughts?
('96 w/ V6)
- The air flow should be fine (K&N stock replacement filter), coolant level is fine, fans work, and I had my thermostat replaced about 3 months ago to see if it would fix it. -
:wave: THANKS for your help!
JW
('96 w/ V6)
JW
