Hey guys, I need some help. Four of my six spark plugs wells have oil in them. I'm totally clueless when it comes to most anything under the hood of my car. For some reason I first thought it was my valve cover gaskets, but I have been told that it could be the piston rings going bad.
I was just wondering if anyone has had the same experience and what you did to fix it. Also, if were to be bad piston rings approximately how much would that run to fix? Thanks.
Yep, its the VC , common mx6 problem, if you use the search there are tons of info on this problem, and i even think there is a walk/how to fix somewhere also
