1 - 20 of 24 Posts
There a kid that i want to race, he has a '92 ford escort with the 1.8 in it, he also has a intake system, a racing clutch, and a euro exhaust. he says his car will put my '93 mx6, v6 5spd stock other then a euro pipe, to shame. I have seen his car in action and it sound like a lawn mower, watch out for the weed waker. @- . so what do u think should i run him or will he take me.lol
:flamer: euroed out escort
Those escorts with 1.8 only have 127hp, w/ 114lb/trq
You have a 2.5 V6, 165hp, w/ 160lb/trq.
I think that you should be able to take him even if you have a bad clutch.(how bad is it?)
But what kind of racing clutch does he have? Might make all the difference in the world.
escorts suck
I think that its a stage one but Im not sure. my clutch starts slipping when it get warmed up, so have i start having problems with it after about one race.
my car
my car also has Bosch platinum 4 in it, they were just put in before i bought it but i know it needs plug wires, what kind do u recommend. i only have 500 mile on my oil change but idk about me air filter i havent check it.s
So is your clutch slpping to the point where your RPM's are reving faster than you speed?
What do you mean?
Re: my car
NGK are the best for mazdas. 7mm or 8.5mm your choice.
Re: Re: my car
Will it make a difference in performance, from 7-8.5?
not really... but it will affect your gas mileage.
Plugs and wires don't do much at all without some type of ignition system. You might see a .5-1hp gain... hardly worth the cost.
If you are bad enough to make fun of him, then you should be able to beat him as is. Trust me when I say as long as that 1.8 is not the Mazda 1.8T bpt engine, then you are fine.
I'd say if you are worried about it, then get a new clutch and lightened flywheel. With intake/exhaust work, that will net you LOW 15s to high 14s if you are a good driver.
Good luck man :cool:
p.s. Who calls it euro exhaust? I guess that is a northern thing.
HAHA...I have never heard it called that either. Yes you better be careful with some of those Escorts. Especially the GT's. Also, like Aggied said, there is a drop in BPT Mazda 323 engine that would be killer in an escort. Better watch out.
-Chad
when i had my stock rs, this older escort (maybe late 80's) wanted to race me, i had 3 friends in the car, he had a really ricey sounding exhaust and i doubt much of anything else other than a wing, we were pretty even with me maybe slightly pulling until we came up to traffic....but this one must be atleast a little faster if we are discussing it racing an ls
just look under the hood to make sure there isn't a turbo sitting in there. for the 1.8's, the motor swap isn't needed, just the manifold/turbo. but if you say his exhaust is high pitched and nasty, then it's probably not a turbo. turbo motors usually produce a nice deep tone.
The Anti Rice said:
I have NEVER lost to an Escort... Never raced one with a turbo though... Didn't know you could do that. Ill be on the lookout from now on.:(
You would be surprised at what you can do with an Escort ;) :D
If he has only the mods you listed, then you should be ok in terms of beating him. Although, I have seen a NA BP Escort go 15.5 with minimal mods, it should be close. They are nothing to scoff at, the 1.8BP is a great engine to toy with!
Only one way to find out though!! Let us know and be safe!
That time came from a car with a bit of extra timing, intake and exhaust. Sure it is not fast by any means, but on the same token, hardly any modification at all. Out of curiosity, what would a 6 run with the same mods?? I am not being a smartass, but I am curious.
A BPT Escort will run you a low 13 second 1/4 with a good set of tires and boost controller. I will be back here to report what a KLZE Escort runs in a few weeks.
Like I said, nothing to scoff at, and not much work involved (BPT is a direct swap). Now how easy is it to get a 6 into the low 13's??
mxmissle9 said:
15.5 is nothing to scoff off? hm...
Well, thats where most of us started off. And I highly doubt you are more than a second less than that without FI/N20. I mean, yeah its an Escort but the BP engine is fairly peppy n/a, and I've seen both an escort and fesitiva turbo'd more than likely with the afforementioned swap, and they were both running 13s all night at the track. I don't think thats bad at all. :shrug:
Suddenly I feel that my car is terribly inadequate. 13's in an escort, did hell freeze over, WOW! thats something else. I would love to see that thing go. I'm am dead serious, I want to race in that just to see the look on peoples faces:eek:! Time to turbo the 6, my goal. To stay together.
1 - 20 of 24 Posts
