1 - 20 of 74 Posts
any hp figures on that motor? its fucking beautiful.
edit: how do you have cooling routed? it looks like its coming out the front, which could lead to hot spots in the rear of the engine :eek:
Cooling
any hp figures on that motor? its [fizzle]ing beautiful.
its no different to having in out the other end......same same, it makes 260-270hp at the wheels.
also has injectors in the air box now. yager performance can make an engine and send it anywhere.
can also do you a who package "lownslow"
cant wait to post the building of my car, :) so glad i found this thread.
Yeah thats choice as man.
Ongoing projects threads are good then you can recieve feedback as you go :D.
Love how clean this engine bay is! I think i will try achieve sililar which may be hard as i have to fit a turbo and all they other bits in there also.
What gearbox are you using?
Break settup?
Iv fitted capri struts with vented disk and going to use austin princess 4 pots with a spacer kit and make the struts coil over adjustables. Not the lightest calipers but they work well. would like to run a booster but not sure were im going to fit that.
On that topic were do you take you vacume from on a turbo motor for your brake booster?
Wonder what i could do to beef up the front end on corners. Good shocks i guess and double sway bar?
Iv just done heaps of development on my daily driver escorts handling and the differance is amazing car loves corners now and you can get her completly sideways with full control.
All new nolathanes.
Much lower profile/streatched tyres.
Koni adjustables in the rear.
Much bigger swaybay on the front.
Shortaned the front shocks with new springs.
and a 3.6 diff to match the new wheel size.
And its like a new car ... so now iv realised the difference that can be made i want to get this cars handling right the 1st time.
What linkages are you running at the rear end? keen to stay away from 5 linking. So what would you recomend? 3 /4 link?
Cheers
Thats choice, do you have there email address?
Got half a doz mates who would be keens on things like engine mounts, engine managment, induction, extractors etc.
If you don't mind me asking what would a package like that cost? Looks like that do good work.
Chris
Sorry to spam your thread mate, but...
Don't propagate lies!! This is known to not be true and never has been true. It's not true when the correct headgasket is used and has been an issue on ALL rwd mazda 4 pots since christ knows when. Again, a well known fact that plumbing it wrongly can screw you and that even with it plumbed correctly for the headgasket involved the front front setup is very sub optimal.
mazdas work right fwd. toyota and bmw at least get it right no matter what, but not mazda.
Fred.
Fred.
Well the engine hasnt had any heating problems what so ever, and its been racing 4 ages, also been doin g 8600rpm every gear, heat isnt even worth thinking about.
Chris
[email protected]
we recently did a whole package for 20k, engine, box, diff, drive sharft, rear springs.
we get good koni shocks and weld a sleve over it and make our own adjustable strut tops. then get some king springs.
just using the gear box you are using.
havnt had any problems with them. other then braking the selecter sharft from brutle use in racing.
can also get a dog box made up, which is what we use in the race cars.
Breaks, use us brake on the front with willwood single spot on the rear.
Discussion Starter · #12 ·
Wheels N Diff
Very upset, cant run the 13"x7" wheels.
dont want to go to the hassle of choping up a diff so i have to get wheels made.
need a fwd type with a gay offset.
also means i may not be able to use superlites.
Im stressing a little, im starting work on the car on monday night, have 12 days to totally complete it, engine, box, tunnel, diff, brakes, suspension, wheels, fuel tank, gaurds, not to mension the wireing and tunning of the motor, and getting the motor built ARHHHHHHHHHH
how is your diff coming along lownslow
WOW! thats the most insane challenge iv heard in a while! or though at the moment I'm re shelling a mates written off show car mk2 cortina with a six week deadline for his weeding and the shell is a rust bucket.
My time line for this project is one year. Mostly financial restriction and i want to take my time and enjoy the build.
With the 13x7's i run a 3.5 diff and its mint! However thats with a pinto motor that is more torque than revs. If your engine is going to be a screamer you may want the smaller wheels? they clear most 4 pot calipers.
What is your stud pattern now? you could re stud your hubs to 114 x 4 or similar common OS RWD pattern.
Have not touched the diff will shorten it last once i have mags and the arches fitted which is a while away as im custom making some 3 piece mesh wheels to get some sweet dish.
Discussion Starter · #14 ·
Progress
Hey, ive got the engine mounts done, tunnel is in but havnt cut old one out yet, diff is almost in, need U bolts. rear brakes are done, massive things they are. Got a drive shaft, its only a one peice so its a temp shaft! trying to find wheels that fit....no luck yet.
drop tank is getting made either tomorrow or thursday.
HOPEFULLY it gets done in time.
And to the guy that was having a winge that there will be hot spots in the engine..... have you not heard of a Kia Sportage???? they run the water out the front.
Anywho, i gotta get back to work!
Discussion Starter · #15 ·
Wheels
LOWNSLOW, what r those wheels off?
they look like they have the right offset..!
and the Zepher hubs are the go, but they are extremly hard to find.
if you come across any let me know so i can get some, thanks.
Discussion Starter · #16 ·
Front Hubs
LOWNSLOW!!!!!!!!!!!
only just got informed,
we are working with a guy that is going to make aluminium hubs for the escort.
when i get them ill let you know if there good.
Holden 5x120 but just found crack in one of them so guttered!!!
Email this guy, he has some he wants $200 NZL$ for them [email protected]. Didn't realize they where so rare perhaps i should get them for future use :rolleyes:
LOWNSLOW!!!!!!!!!!!
Oh choice sounds like the go! Just need to find yourself some wheels now :D and im guessing you can basically choose anything now!
Nice Escy.
1 - 20 of 74 Posts
