1 - 20 of 22 Posts
you mean the slight piece missing from under the spark plug hole? id say your fine, but im far from an expert on heads.
The piston hit the head. You could see it next to the exhaust valve
you have a nice imprint there..............
and as noted, a peice missing from under the spark plug hole.
Thats a big imprint btw.......what broke?
The Rod broke and slap the head :lol:
wow a rod fracture!! I want pic's of that!!!
bearing failure, or was the problem the rod?
This was from a Lx motor it had a CAI all the way to the bottom and suck water to the intake manifold so water got inside and i kept running the car and it was knocking hard until it died :lol:
Go have the head shaved.
Sand the rough parts around the missing piece at the spark plug hole.
As long as none of the indent touches the lip on the head gasket you should be fine.
Just remember to torque the head down to spec, let it sit one hour and torque it again.
Discussion Starter · #12 · (Edited)
^^ nah that is going to the trash. Im looking for a f2t head and i know that they are the same with the f2 expect the exhaust valves but i want a F2t head.
speaking of which does teh F2t use a different head than the F2?
Trying to map out my hybrid on paper here. All the things i'm snagging from yards soon.
BTW, awesome damage to head lol. I love the imprint of the cylinder.
Keeloh said:
Im looking for another but f2t i know they the same expect the exhaust valves but i want a F2t head
Read much before you post?
-Tyler
heads are almost identical. Some people believe the exhaust valves differ though.
Reactions: thefallenangel1
Discussion Starter · #16 ·
The Turbo Head comes with E1 exhaust valves and non Turbo are E0
Susposedly, the turbo heads have sodium filled exhaust valves. Some people have cut the valves with sawzalls, and said "it was harder to cut the GT valves with my 8.99 harbor freight saw than the NA valves, they must be sodium filled!"
-Tyler
im pretty sure they are just hardened, not sodium filled. i got a junk head laying around if we really need to know.
lmao
i say DOOOOO EEEETTTTT
so what does that mean though. They exhaust valves are bigger i'm sure since the temp's in the engine are higher in the turbo i'm sure the engineers wanted to get rid of it quicker. But anyway whats it mean?
funny you say that cause i bet i have the same 8.99 saw :)
I also have the veterans day special 19.99 for a sawzall with adjustable speed with 9 blades. I'm full of win tonight bay bee!
Discussion Starter · #20 ·
Im also down to cut this fucking E0 valves lol
1 - 20 of 22 Posts
