1 - 8 of 8 Posts
1990 Mazda Persona F2T
Hi everyone.
Trying to get my car going, but the distributor seems to be the wrong one.
Plug is the same though.
Can anyone tell me the difference between a non turbo and turbo distributor?
I know it's different between years, 88-89 is different from the other years.
The disty cap is definitely different, that's how you can tell between them, but I've used both variants and they worked on a 88 gt
What do you mean by doesn't fit? You can't physically fit it into the head? Bear in mind that the key slot is offset so that it will only fit with the rotor in the right direction.
It was a simple solution in the end. Turns out the rotor wasn’t lined up with the key slot.
1 - 8 of 8 Posts
