Does anyone know the power outputs of the 1800cc cousin of the FE3 DOHC?? Just interested, there seems to be a lot around, many with alloy sumps, low k's and almost half the price! Are the cyl heads the same (valve sizes, cams, etc)? I know the block is not as tall by about 19mm (making it much easier fit in an MX5), due to the 77mm stroke (down from 86)..the bore is the same at 86mm. Conrods seem to be shared with FE SOHC, DOHC ones2mm shorter at 150mm.
If it makes 150hp or so, i could nearly be tempted into one of these!
Cheers,
Tyrone
F8 is the un stroked version off the FE DOHC. So i would hazrd to guess smaller valves cam and head ;)
Power output around 115hp or so...but they are ideal for forced induction :)
