· Registered
HEY FOLKS, I WANT TO ASK A QUESTION IN REGARDS TO REMOVING THE MYSTERE, MX6, V6 OR MAZDA SIGNS IN THE REAR. WHICH WAY IS THE EASIEST TO REMOVE THEM????
they aren't bolted, but they do lock into holes. if you get a flat head screw driver you can pry them off, but you are going to have to put something to fill the holes and then get it painted. i am about to do the same thing.
· Boostaholic
I removed all the badges in my '93 LS rear end. Looks nice and smooth now. However, yes I did weld those holes and re-painted the arse. Pics will be coming out to see soon.
Mici
· Registered
just a warning DONT USE A SCREW DRIVER!!!!....unless u dont worry bout scratches!?!?!?
try using dental floss, just work it between the body of the car and the badge....and pull, it should simply wiggle out!!!...
u can also try using a credit card or sumthin' like that
hope this helps
