What size are the factory door and rear deck speakers? Also, does the door panel have to be removed to replace the front speakers or can you just remove the grill?
Anyone got subs in the rear deck firing off the rear window? I'm thinking of adding a pair of 8's in the center of the deck and wanted to know how much trouble is involved in that.
front and back are 6 by 8. you have to take the door pannel off to get to them. the back you take the grill of and there are 4 screw to remove the holder and the speaker as one. i have 6.5in all the way around in mine and 4 tweater and one 10 in the trunk.
this should have been here.
jdmxsix i am putting in 2 12inch hx2 what amp would you recommend and would you also recommned a cap, so i diont drain the alternaotr in my car now i have an alpine tapedeck wit 12 disc cdchanger and infinity kappa rears and tweeters what amp should i get for the box the rms is 1000 each peak is 2000 together
