1 - 9 of 9 Posts
~F2T Motor Build Pics~
i dont post much here, but figured you would like to follow my newest motor build.
ok, we will start from the beginning..
the reason for the rebuild...
we will just say we hit a lean spot ;)
heres the carnage of removing the motor...
Discussion Starter #3
heres all the new toys.....
included in the pic is the .30 over bored block.
remanufactured head.
clevite .30 over, 8-6-1 compression pistons.
clevite 77 .30 over rings
clevite 77 main and rod bearings.
new OEM mazda head gasket.
new OEM mazda head bolts.
felpro top end gasket kit for everything except the head gasket.
Discussion Starter #4
heres pics of me rebuilding the head because the machine shop didnt know what the fuck they were doing, and didnt seperate the intake, and exhaust valve spring keepers. good thing i double checked there work. and redid it all cause there useless.
Discussion Starter #9
well we finally got it in. we only spent maybe 2 hours on it today, but got a decent amount of things done. all the wiring is done, all mounts are filled with 3M window weld, and installed. most of the vacuum lines are done (1st gens have lots)
1 - 9 of 9 Posts
