Dont waste you money on some blinker mod on ebay. This is free.
This will work for sure on the mx-6 and more than likely any car. The whole point is to trick the ecu into thinking the bulbs are burnt out. Heres how to do it.
Go to the plug in on your front blinkers. There is a black wire. Simply cut this wire on both the front left and right blinkers. Dont cut the rears. Once you have cut the front two all four will operate the same. Now go turn on your blinker (be sure your key is on :D ) and they are blinker twice as fast as before. Now turn on the headlights and hit the blinker. Now they are 4 times as fast. })
Thats all. I am in the process of finding a way to make the blinkers blink like they are on crack. I will update this when I figure it out.
Later
Any quetions?
To add to this, it works, and it is nice, to put LED bulbs in the rear turn signals. Current will flow easier and the signals go mad.
