1 - 16 of 16 Posts
How many cc's are them? is there any other direct-fit?
people tell me they only can deliver fuel for like 180-190hk =/
is there any 370cc from any other car that fits directly?
why would u want to go bigger????
do u have a turbo setup??
yea, turbo on the go. but making research/buying stuff atm
Bolt ons
Hey man if you are looking for big numbers and using a
Rising Rate Fuel Pressure Regulator then you can use the RX7 550cc injectors if you don't want all that fuel then the supra 440cc are just great.
Re: Bolt ons
i'm thinking of 370's of 440's. You think the 200sx s13 is boltons?
I'm planning to use a Apexi S-AFC
If your using the SDS you dont need a RRFPR. All you need is either the stock FPR or on by AEM. This is because the SDS controls the injectors and you can program in the correct settings.
evo
evo
hmm? don't understand
RRFPR?
FPR?
SDS is a standalone engine managment system...right?
Rising Rate Fuel Pressure regualtor= RRFPR
FPR= Fuel Pressure Regualtor
SDS= Standalone computer
*goes to fridge* *finds bottle of evan willams* *takes swig* *falls asleep and pretends this discussion never happened*
evo *zzzzzzzzz...zzzzz*
Discussion Starter · #12 ·
i guess if i up the due-cycle of my injectors with a AFC i also must buy a fuelpressure regulator?
how much is the fuel-pump good for? standard FE-doch
all depends on how much you want for them though...
Discussion Starter · #16 ·
now i got my injectors , 440's lowohms from a supra, they seem to the same diameter as the orginal fe-dohc ones
1 - 16 of 16 Posts
