I have been asked to do the FE3 faqs again and sort though the last super post I made, so there will be up to 83% less flulf and 17% more info. Enjoy!
This thread composed on info from this thread.FE3 and everything else
It took about an hour and a half to sort out most of the usless info.
I guess that when people do a search for FE3 they come up with alot of useless threads telling people to search and when they do ask they get a lot of harsh answers. (sorry to all that have recieve harsh answers from me)
So to make it a little easier to find FE3 info I have made this thread. Feel free to add on to anything I don't cover.
First question:
What is FE3?
Fe3 is a 2.0l 16v DOHC engine that is found in euro and japanese spec mx6, 626, and capplea cars.
1998cc 121.9 cu in. 2.0 liters
86 mm bore 3.39 cu in
86 mm stroke 3.39 cu in
Aluminum head, cast iron block
Dual overhead camshafts, 16 valves
Here is a pic from FE3Ts site.
THis motor cam in a few different trims.
9.2:1 compression on cat models
10.0:1 compression on non cat models
[email protected] 6000 rpm 10.0:1 models
160ft/[email protected] 4500rpm 10.0:1 models
[email protected] 6000 rpm 9.2:1 models
140ft/[email protected] 4500 rpm 9.2:1 models
(from JayB's website)
Will it fit my car?
As long as you have a 88-92 MX6,626, or Probe.
Is it a direct fit?
Yes, everything bolts right up.
Can I use the DX/lx tranny with FE3?
Yes, just be carefull with your shifting and if your planning on adding boost you may want to go to the GT tranny
Can I use the F2T or F2 ecu with FE3?
Yes, you can as long as you extend the dissy. You can use the F2 or F2T ecu but it will not running the FE3 as it is intended.
A better option would be to use a standalone ecu or FE3 ecu. OR EITHER A NISSAN CA1ET, OR MITSUBISHI 4G63 ECU AS WELL
Can I use the BP ecu from a protege?
Yes you can as long as you have all the wiring and proper conections.
Whats is VICS?
The intake are also a jewel.
its a variable intake with 2 sets of runners.
1 long set for low rpm torque and 1 short set for high rpm power
(picture from FE3Ts site)
Also you can control the vics operation with a stand alone ecu or an rpm activated switch.
What parts do I use for FE3?
You can use 98 KIA sportage parts, like the water pump, timing belt, head gasket, pistons, etc...
Use F2 oil filter, miata spark plugs or just go to the parts store with the ones that came in the car. As miata sparkplug wires.
What is the performance of the FE3?
The FE3 is just a little faster than the F2T. It revs higher in the rev range but doesn't produce as much tq as F2T. You can expect low 15s runs from a well tuned FE3 and posably 14s if you a good driver.
Also It has been noted that FE3 has a top speed of just over 280kmh or 150mph.
Was there ever a turbo FE3?
Yes, it was used in a rally car in the early 1990s. Only 28 were made. They the engine code is FE3T. They are not avaiable. PART NUMBER WAS NOT EVER CALLED FE3T, IT WAS A FE-T DOHC, AND THESE ENGINES WHERE RACED IN THE 80's NOT 90's. NO ONE CAN GET THESE SO DON"T ASK!!!!
Can I turbo FE3?
Yes. Turbo FE3s produce huge amounts for hp. They are capable of over 500hp with a turbo. One guy had his FE3-T runnig 11s 1/4mile times.
Where do I get FE3?
Check with your local Japanese Engine Imports. Also there are avaible in Colorado at a place called All Japanese Engines
Ph: 303-234-9528
They should be able to souce one. But make sure its complete.
Here are some more sites and things to read regrading FE3:
FE3T's website
Turbo Chat FE3 info
Randy's site
wiring diagram
valve keepers
evo vac lines
evos fe3 coming in soon
FE3 vs F2T
FE3 started
kia part numbers
vics controler
FE3 in probe
rev limting problem
FE3???
FE3 thermostat
Fe3 debate
evos thoughts on fe3
cheap turbo for fe3
misconspections about fe3
SDS install
FE3 Timing
FE3 talk (some info on this link may or may not be correct) FE3 revlimiting problem
Another Evo rant about using FE3 parts on the F2T (its not worth it!) FE3 overbore Q? More on SDS
Q: I'm guessing the manual trans that came with the FE3 in the Japan cars isn't any stronger than the MTX in our cars and also came without a LSD?
Does the FE3 use hydraulic lifters and are they located in the tip of the rocker arms like the F2?
I would really like to see a close up shot of the FE3 with the valve cover off.
A:FE3 uses bucket type HLA's same that are used on all Mazda DOHC engines such as B6 DOHC, BP DOHC, FE DOHC, K8 DOHC, KL DOHC, FSDE DOHC, KF DOHC engines. But the FE3 uses the largest out of all of them, so you can't used the others.
It's no such thing as a stronger Mazda tranny, even if it's from Japan, Africa, Russia, Austrailia, or what ever it is... It's no such thing, the only thing maybe if it's LSD or not.
All Mazda trannies are same strength world-wide (WEAK)
FE3 uses a MAF sensor not the crappy VAF that the F2T uses.
Q: this motor looks almost exactly like my friends protege engine, is it the same?? i think his is like a 95 lx
A: No the BP motor that the protege/ 323 use is not even close to the FE3. Parts will not transfer.
Q: what all needs to be done to fe3 b4 they can get a turbo. is it pretty much the same: pistons, rods, and all the other typical things
A: If under 12 psi nothing really. The rods are fine and the cat model pistons (either 9.4 Mazda or 9.2 Kia) are fine. Only if you get to wild boost numbers do you need to look at pistons.
The only reason I(Randy) got aftermarket rods is because of the shorter length requirement from the stroker crank. The aftermarket Chevy rods that are conservativly rated at 500 hp were nearly identical in size to the factory FE3 pieces. Its all about the tuning.
More FE3 head pics, thanks Dutch626.
evo
First question:
What is FE3?
Will it fit my car?
Is it a direct fit?
Whats is VICS?
Can I turbo FE3?
Where do I get FE3?
Ph: 303-234-9528
FE3T's website
Turbo Chat FE3 info
Randy's site
wiring diagram
valve keepers
evo vac lines
FE3 vs F2T
FE3 started
kia part numbers
vics controler
FE3 in probe
rev limting problem
FE3???
FE3 thermostat
Fe3 debate
cheap turbo for fe3
SDS install
FE3 Timing
evo
