Feeler For Custom CZT Style Intake Manifolds, Roof Support Bars, & Rear Sway Bar Kits
This is a FEELER Thread only, I am trying to decide if I should take further action on some of these options, all or none. So please tell me your thoughts, interests and lets go from there. (I got permission before posting it so please do not delete it this time, let me know if I made an error or broke a rule first... I hate rewriting it lol)
1st) Custom Intake Manifolds based off the changes made by CZT with my own additions. A bulk Buy Price of around 550 for the first 5-8 Units between here and PT is what I am thinking. Before the Bulk Buy Even happens all units will be finished so there are no CZT Nightmares.
For those who do not know about it let me give you some information:
- Single Plane Style, Mounts right in the center
- Velocity Stacks
- Easy Access to Rear Plugs and the back of the block
- Uses Stock Rails and Throttle Body
- Differences for N/A and FI (N/A will have Changes for Air Channeling where as the FI will be the same as PMO with there shown 37WHP Gain)
N/A I believe it was shown to be around 25WHP depending on Mods.
There used to be a lot of information on CZT before the incident. I will def be making sure the same problems do not come up. With the first batch we will be paying for the jig to be made after that when an order is placed it is made right away. If the Jig is not available as the shop we will be doing the work at does have hours and holidays esp during the Sand Dunes Popular times. (Not to mention he builds many other custom vehicles) We will ensure no orders are allowed at those times.
Ok here is a thread with some, there are only 2 of these manifolds in existence and until a weeks or so ago no one even knew this one existed.
ProbeTalk.com Forums
We have boosted numbers for sure:
Millenia 14psi 280whp
CZT 14psi 318whp
I am working on the N/A Information now.
It does seem there might be a loss of torque on the low end but I am looking at the Splitz Manifold (I think that's how its spelled) that there were also only a few of. However on the Top end it seems the gain was between 18whp and 23whp depending on TB Changes. However its very apparent if your going to go Higher reving (As mine is setup for) your def going to enjoy the difference as the above information was with the stock rev limit.
I will continue looking and my Manifold changes for N/A should also help but until my changes hit the Dyno (Some changes Rusty and I talked about over 2 years ago when we started thinking about doing this ourselves but he ran into a lot of outside work that was more profitable). So Again until true numbers are posted this is just searching around at what we have available.
Pics of the Manifold I currently Own and will be Modifying:
2nd) Roof Support and Brace Bar
This is pretty self Explanatory and will be easier to build however I am looking into make again 2 models.
One like mine and one that is a little stiffer for those who remove the rear seats.
Pic of my current one:
3rd) Sway Bar Setups with Adjustable Endlinks
Now this idea has been done before. I have a few options from 17mm to 22mm that I think will be easy and cheap for everyone. Around 150 for a kit size will not make more then a 30.00 difference in price.
I am also looking into making the End Links Grease-able.
So what do you guys think? I would like to know if your serious on the IM's as I am probably going to move forward with that before Christmas for a Jan. Bulk Buy if things look good.
