This is a Final for sale, After this it will be put on ebay listing or sold locally.
Get it here for LESS.
The Details:
$100 + $10 Shipping.
There are no competitors on this bar, There is nothing similar or the same.
For a Side note, The bars made by other companys sold for $80+, Made from steel and used L Brackets for Mounting. This isnt just a peice of flat stock aluminum and aluminum tubeing. This is a Unique special made tubeing with rolled edges and crease's for strenght.
Additinal Pictures by request.
Paypal, Check or Money order accepted.
Please paypal [email protected]
Or PM me for address.
Thank You.
The Details:
- I have only 2, This is 2 of 3 only made. There will not be any others made, due to lack of material.
- This material is Very strong, it withstands 450ft lbs of bend pressure, It will not bend ever. This is the strongest B pillar bar you can get, it also will not flex.
- The streetthis bars or similar bars have are able to flex due to there design, this wont.
- High Quality Welds that Are buffed down to give a clean and sleek look.
- Available in Sanded, Brushed or polished, no additional charges.
- This bar weights less then all of the steel Bars, it weights aprox 2lbs.
- Bolt on design, There are no extra modifcations needed to install. You use the existing hardware on your car.
- This is the lowest profile bar made, the clearence between the roof and the bar is aprox 2.75in.
- A camera Can easily be fitted to the bar.
- Rear Seats are easily functional.
- All Aluminum Construction, It will not rust, It will not corrode, It is Paintable.
- Retain a Performance Tuner appearence, Rather then an all out race dedicated appearence
Thank You.
