Anyone ever flushed their rads, with one of those prestone flush and fill kits. The ones where you got to splice a rad hose and fit a T adapter in between the two hoses. Is there anything I should know before doing this? Also If I use this method, does that mean that I can avoid having to drain the coolant from the rad and unscrew the water coolant hoses on the oil fiter?
