I drove yesterday in 100* heat. It wasn't the worst experience of my life but pretty miserable with no ac and no fans. That said the car did great with the only exception being an oil leak causing it to smoke when I stopped.Must be roasting in Portland this weekend
Overall about 60miles on the car yesterday likely putting about 100-120miles on the engine total! I'm much more confident in bringing the car out and driving it longer distances now. Oil pressure was good the entire time, afrs need work, but after reviewing logs coolant temps averaged sub 190* with a peak of 206*. The hood and radiator are working perfectly! Intake temps peaked at 122* but I'm not too concerned with that yet as I havent broke 8psi yet and that feels pretty low still!
Also starting to experience torque steer again. 7psi on this setup (9.3:1cr and a bigger turbo), is feeling like 11psi on the old setup (10.5:cr and a smaller turbo) and it's like 30% dialed in. I guess that's to be expected considering all the changes Ive made since last time. World Challenge Protege Cylinder Head and Cams, bigger turbo with newer tech, and lower compression.
