rock auto. Or bosch, i got mine at autozone.
Yes, they will. I'm currently running the exact same ones I bought last year from Allmazda.:tup: Top quality mounts also, I may add.Will those Monroe mounts fit my Tokicos?
just to go off topic, looking to buy some new lateral links?allmazda - also, any luck on those lateral links?
I just sold my new OEM lateral links to Allmazda this past spring. I managed to get mine from mazdapartscheap.com for ~$350 shipped for all 4 links. They were a major upgrade from the old rotted ones. I know he was busy last spring and couldnt help me out, but maybe Allmazda can help you get some cheaper than thatThanks for the recommendation. And, yes, I am. Looking to replace the trailing arm bushings also, if not both trailing arms. The old girl has treated me well for 19 years, but some things just wear out!
What strut mounts did you use for your old Illumina/eibach setup? The same monroe strut mounts? 1G or 2G mounts?Yes, they will. I'm currently running the exact same ones I bought last year from Allmazda.:tup: Top quality mounts also, I may add.
I am going to be doing that similar setup myself. However, my original strut mounts are worn out. So my plan is to get the non GT strut mounts with the metal bearing. Hopefully I don't run into any fitments issues.On that setup it was just the stock 1g mounts.
Personally I dont even like using the stock 1g mounts woth those in the rear. the spring didnt feel like it ever fit correctly.I am going to be doing that similar setup myself. However, my original strut mounts are worn out. So my plan is to get the non GT strut mounts with the metal bearing. Hopefully I don't run into any fitments issues.
