Hey guys... when trying to start my car... a ton of fuel leaks out of the exhaust manifold... someone told me its probably an exhaust valve stuck open... the engine has less than 70k miles on it... Another thing that is weird... is that i get 150psi in each cylinder... so the compression is good... the timing is on... what else would cause fuel to leak out of the exhaust manifold??? and, if infact the exhaust valve was stuck open... wouldn't i get a bad compression reading??? thanks for all your help in advance... karma for all help. oh... and P.S. i thought it would be an injector stuck wide open... but i switched fuel rails... and still the same problem. 93 mx6... 6 cyl ls.
