Are you saying the leak is coming from the clamps/hose?
The leak is coming from one of the vent valves. The rubber seals on both vent valves are really cracked and they also seem a little melted? Not sure if the previous owner put something on those rubber parts and that messed them up.Are you saying the leak is coming from the clamps/hose?
It was worse when the tank was full. I would only notice a few drops while parked, but the car always smelled like gas.When did it leak ? These are just passages for vapor, not fuel. Did it only leak when you completely filled up the tank ?
Thank you. I can only find Probe ones.Yes the probe uses the same ones
