So here is the deal, I have a 97 Mx6 LS V6 and my Tach, Speedo, and coolant gauges all went out. Yet my fuel gauge still works.
My lighting still works aswell as all the dummy lights.
I changed the meter fuse and took my multimeter and checked both sides of all the fuses. All good.
I had a spare cluster and through that one in and the same problem existed.
Prior to this failure all three gauges would flutter once in a while, and a cel light followed by a speedometer sensor B code.
I've been searching and found people with similar problems but no outcome was posted.
My question is can this sensor be the cause for all three gauges. If not has anyone have some feedback that could help.
thanks,
-Steve
I had this happen to me as well... twice since i've owned the car...
But usually only for about 10-15 minutes... and then everything would start working again fine.. it hasn't happened in several months... so i never bothered looking into it...
but i'd be interested to see if someone knew what it was...
