1 - 1 of 1 Posts
Water Temp:
Need to fing out where to install the temp sender module? like 3 different size connectors come with it, I just need to know where I need to install this or if I have to drill a hole and then tap it in order to scrw in the temp sender.
A/F Ratio:
Which wires are you supposed to hook up the gauge to? From the O2 sensor, which one? front or rear?
Thanks in advance!
1 - 1 of 1 Posts
