Have a spare set lying around which could probably be put to use.
They are slightly damaged, though still roadworthy. Part of the plastic shell has mounting points where the grille would normally clip in place, those points are damaged. If anything, you would just need a creative way of securing the grille. The pics below will outline what I mean.
Other noteworthy points are that one of the low beam vertical adjustment screws is broken, not really an issue as you can remove the adjustment screw to expose a shaft that can be used to adjust the angle. Also these lights are missing the caps for the low beam - also shown in pics below.
Note: Indicators are not included.
Looking at $50AUD - plus postage if required.
RHS bracket damage
LHS Bracket Damage
Faulty adjustment screw
Missing caps
