hi there guys im having a wee problem with my mx6 :(
it seems to be having difficulty in going into 1 3 5 gear 2&4 seem very easy but the others are very stiff as if you need to force them into gear please help as i don't want her to end up on the scrapheap
I had the same problem once. After a hard shift, one of the sets of bushings had broken and lodged such that I was not able to push forward enough on the shifter to actually get the car into 1 3 or 5 easily.
Super Moderator
Hi Eddie
It'll be something causing a short throw forward. check the linkages and/or rods from gear stick to gear box.
Elmer
Discussion Starter #4
hi there guys i managed to sort out the problem it was the extension bar under he gearshift that was snapped in three places so it was basically like an accordion i manage to gt it cleaned up and re-welded each snapped area before it was all ready and probably stronger and now my gear change is sorted thanks for the advice ppl
