Guest
·I have swapped the manual gearbox on my 93 2.5V6 and now the car will not idle. If I start it up from cold it will idle very unevenly and almost stall but when it gets warm it stalls immediately unless I give it throttle, it seems to drive ok (i.e. under throttle) but stalls as soon as it comes to a stop (clutch in or in neutral).
The engine ran fine before I swapped the gearbox, which was off a probe, everything was identical to the box I removed.
I have double checked all the hoses and connectors have been put back as they were before, any ideas on what I should check or may have missed would be appreciated.
Rob
Rob
