Acording to Mazda the 2nd Gen MX6 requires 75W90 GL4 oil. Most of the 75W90 oil I found is GL5.
What gearbox oil do you reccomend?
Have you found somthing that works better than 75W90 GL4?
Is GL5 OK to use?
Cheers
P.K.
THE best is redline MT90 and MTL in a 2:1 mixture depending on your temps where you live.
if you read the site posted above you will learn NEVER to put in mobil 1 syn gearbox oil as it damages our synchros or something. if you go with the redline you won't be dissapointed.
