I am purchasing a 94/LS. It has all the bells and wistles except dual power seats and cd player. It has 60,000 miles. This will be my first one. What kind of problems should I start to look for in the near future? I have driven the car and have seen no appearent probs except a slight knock coming from under the front valve cover. Any suggestions will be appreciated. Thanks for everyones time....
Rob
Mpulse Productions, Inc.
Check for oil in the spark plug wells, rear calipers on '93 & '94 models have been known to seize. At 60k mi definitly make sure the timing belt was replaced.
Oh and this post should have been under 2nd Gen ('93 - '97), not 1st gen
Welcome and congrats. That noise is probably noisy HLA's which can be alleviated by using synthetic blends or full synthetic oils. Mobil 1 oil is sworn by many here. Timely oil changes are important too. As far as frequent probs, there are the rear-calipers, 02 sensors, valve cover gaskets, distributor, timing belt is due to be changed. The engine is non-interference so if it does break you will be just dead in the water. This question has been asked a lot so you can do a search in this forum for "buying mx6" or something like that and you will be able to pull up more info.
At 100K+ it is fairly common for the oil pressure sender to start leaking oil. I don't remember how much it was, but it might be worth doing a preemptive replacement at 95K to avoid running out of oil unexpectedly.
