hey guys im new to this forum so bare with me if im not up to speed
im currently got a 1998 mazda capella fs-de engine sitting in my ford econovan just installed and have wired up a megasquirt1 to run the engine im using all the standard sensors minus maf sensor, cam sensor and idle control valve. it's running standard injectors and wasted spark setup with a subaru ignitor i am a newby to the megasquirt ecu btw
i have gotten the engine to turn over and idle it splutters a little bit, but soon as i open the throttle it'll die what do i need to do to sort this problem?
also does any1 have settings for a megasquirt for a fs-de engine?
Vendor
Could you post a data log of the problem and a copy of your MSQ file? This will give us more to go on. Could be a VE table tuning issue or acceleration enrichment.
