OK...IVE DECIDED TO GET NOS......HAVE A 2G V6LS...WHAT SHOULD I GET (SIZE ECT.) AND ALSO SHOULD I GO AHEAD AND DO ANYTHING TO MY ENGINE AS FAR AS REBUILDING ANYTHING TO MAKE IT STERDIER?? AND LAST BUT NOT LEAST...WILL INTERCOOLER ALSO HELP ME....GOD IM LOST WHEN IT COMES TO PERFORMANCE, SO MANY CHOICES, SOMEONE PLEASE HELP....GRRRRRRRR
THANKS PEEPS!
turn caplock... (are u yelling)
Try reading the FI 2nd gen forum about Nitrous Oxide. Nos is a brand name.
I Would Recommend ZEX Wet!
This kit is really easy to install yourself..all it was was 4 wires...
There are two kinds of nitrous systems you should be looking for (i know there is another kind but main ones) Wet and Dry:
Wet: this spray the nitrous into your intake along with the proper amount of gas needed...this is the safest you can do
Dry: this sprays the nitrous into your intake and then tells your fuel injectors to make up the fuel needed..not bad but really dangerous when it comes to bigger shots
Both systems have a nozzle that mount into your intake elbow...right before the throttle butterfly
In order to handle this extra power you should upgrade a few things:
Necessary Modifications:
- Clutch (if Manual)
- Tranny Cooler (if Automatic)
- Fuel Pump (if using a shot over 55)
Optional Modifications To Benefit Nitrous:
- Intake
- Headers
- Cat-Back
I think thats it....but ask anything else if you want
an intercooler is for a turbo... not a nitrous application.
So no you won't need one.
