I have posted a few times about trying to get rid of vibrations from the left front side when in the speed range of 70+ mph.
Today they are finally gone.
The vibrations only happened when reaching these higher speeds. They weren't that bad, the mirror would shake a little and also the steering wheel. First improvement came when the rear motor mount got replaced. That improved the problem about 70%, but not completely gone. Also what that did was stop the transmission from sometimes shifting into HOLD by itself.
Final improvement came when the ac condensor was replaced. The new condensor has slightly different sized attachment points at the top, so I had to move the adjusters some. Also on the bottom it has threads to put a nut on.
That finally did it. Nothing to do with the wheel or wheel alignment at all.
