i just scored a turbo off a fe/t and and i have the plain old fe (non turbo) ive had no expierience with tubos before. but i wanna fit the 12v head on my 2l and use the fe turbo on it i also want an intercooler what would i expect to pay for one also will the fe turbo manafold match the f2 head? what else will i need and how much boost is the fe turbo good for? also im told not to worry about the turbo why is that? thanks
the fe manifold wont fit the f2.
putting the f2 head on the fe then turboing may result into some problems as the compression is around 9.2:1 compared to fe compression of 8.3:1.
Also the amount of boost wouldnt be much 3-5psi at most :)
I would recomend using the F2/T Intercooler.
And about the turbo shaft play is the main killer !
good luck :)
