R
Guest
My father owns a '93 MX6 I4 MTX with about 62K miles on it. He's experienceing a groaning noise coming from in the car, mostly from the engine bay. It is mostly heard whenever turning. sounds like something is shifting. I dunno maybe loose motor mounts, or struts?? I was wondering if the MX6 enthusiasts can identify this problem, and if so is there a recall or TSB on it at all. Any info is much appreciated, thanks. If there is anymore info required please let me know thanks.
If the sound occurs only when the steering wheel is actually moving or near full-lock, it may be a power steering pump noise (have you checked the power steering fluid level?)
gotta go with mike on this one. It is either your power steering pump or rack and pinion if it is a groan then knock. I'd hope for the fluid level being low and not the pump going out or rack and pinion itself. Expensive! It could also be his struts are loose and/or old. I had an old mitsubishi that creaked when you break.
R
Guest
Discussion Starter #4
Thanks for the insight guys. I'll let my father know what you guys have given me.
