i want to now if somebody now please tell me i can have the 3 gear from a awd protege from the dealer for 100$$ just want to be sure before
it's also a G series transmission, which is how they're listed, so it SHOULD (not will) fit. also the protege is heavier, faster, and turbo'd, so the gear ratios may be different, which will either make it not fit or maybe give you a funky shift.
also the protege is heavier, faster, and turbo'd.
here in the states, most awd protege's were nto turbo'd. but did have the B serie's motor with a g series trans. and from a quick search, i dont think its the same gear as the GTX. it should still fit thought since it is a G series trans. who knows if its any upgrade off hand though. try out clubprotege.com. they should be able to help you alot.
