That is simply loading the front end of your car allowing the rear to lighten. And since you are already turning, causing the momentum to work your rear wheels around and inducing a small slide.
In other words...a Ghetto-drift...hehe
In a FWD car it is just a small slide, if it was a RWD, as you are sliding, you can correct by apply alot of throttle, creating a get this...Power Slide. And if you can hold that slide for more than a few feet it becomes a drift.
You can also cause the same affect without going at the corner hard. Simply approach at any normal speed. Than suddenly tap the break in conjuction with pulling the e-brake and you will also induce a slide. Make sure your in second gear and power out of it, works especially good in the rain
