1 - 11 of 11 Posts
hey guys,
does anybody here know anything about the supercharged deisel 626 wagons?
i.e power output?
does the engine fit directly into a 1st gen mx6?
how hard would it be to adapt the 4wd running gear into a 626?
thanks
I don't believe the US got that car. What year is it...do you mean "GD" instead of "GV"? Might want to check the australian forum here; they would be more familiar with the vehicle since most of us here are from the states. I believe europe got a 1st gen wagon as well.
never even heard of diesel 626, not to mention supercharged.
If this is true , its going to open up some huge discussions
nah we didnt get it in australia either but i do see some on the road every now and then.
they got it in japan only i believe??..
and nah, i do mean GV.. wagons were called GV, i think they kept the 1st gen shape while 2nd gens were still being made?
ive heard/read stories of there being a kl-ze 1st gen shaped wagon..
i was going to ask about this too. i was interested to see some pics of the engine becuase i heard that it used the same f2 block and head. which means that there could be the possibility of converting the supercharger setup over the gas version.
The wagon was called GV and yes indeed it was made up to '95.
The supercharged diesel version? I knew there must be a 4wd around, but a supercharged diesel 4wd?? Never knew that!
GRZ JORDY
RF is the diesel engine code.
Australia has the RF non supercharged diesel.
here is RF Super info
Displacement, cc 1998
Engine model RF
Max.power (Net), kw(PS)/rpm 82 ps (60.31 kw) / 4000 rpm
Max.torque(Net), N*m(kg*m)/rpm 18.5 kg*m (181.42 N*m) / 2000 rpm
Power density 18.05
Engine type Water cooling serial 4 cylinder OHCICScharger
Engine model RF
Power density 18.05
I belive the correct engine model was RF-CX
The compressor was a "Comprex, Pressure wave supercharger"
introdused by Brown, Boveri and Company in 1913
A = Gas Housing
B = Rotor
C = V-Belt
D = Airhousing
1 = Intake air
2 = Charge air
3 = Exhaust gas from engine
4 = Exhaust pipe
I had an oppournity too drive a FWD 626 Touring Sedan equipped with this engine a couple of years ago.
Performance wise its comperable with a 2,0 8 or 12 valve gasoline engine. Torque was a bit better but it rewed like its gasoline sibling.
The car i drove migth not be representative for its kind due too its high mileage (450000+ km)
1 - 11 of 11 Posts
