Sounds like your overboosting, is the buzzing sound coming from the dash or the turbo itself? I'd check to see if you have any leaks in your intake pipes, paying carefull attention to the 90 degree elbow on your throttle body (Take it off and bend it it around).
If the sound is coming from your turbo itself, then your turbo bearings have so much play in them that they are allowing the impellers to hit the turbo housing. In that case, your pretty much screwed as the housing is scored and the impellers will be damaged.
You'll need a new turbo, and its a good excuse to get a better one. Don't waste your money buying a new one from mazda as they want $1800 for it, and you can get a better one off e-bay for $300 or so.
Oh, and on your poll...What is good is all that appearance stuff if the car doesn't run right?
