What type of headers should i get and where can i get them
and i wanted the cat back borla exhast where can i get it cheap and 1 more i was told to get 4 11 gears for my car whats is your opinion and where to get them>?
Whoever said the gear thing is obviously a V8 guy and probably a bit uninformed. Your gears are fine. Changing gear ratios in a FWD car requires pulling the tranny apart. In a RWD you can change the rear end, and get similar results in a much easier form. It's not worth thinking about.
Using the search feature, (Upper right), will help you find info on lots of things like Headers and Cat backs. As far as headers go Hotshot seems to be a decent choice. If you don't live in a snowy climate Pacesetters may not be a bad decision. (They're cheaper, but not as high quality.)
As for the catback I have no idea. If you watch the forsale section maybe someone will sell a used setup. Or you could have a muffler shop make you a mandrel bent setup pretty cheap comparitively.
try probeparts.com
