ok i tried the sandpaper on my oxidized headlights and voíla! it screwed them up. i sandpapered the headlamps and then used car wax to buffer and now i have a scattered beam headlight... illegal. there's no beam and its like having a light out, so i must get a new headlamp if its not correctable. picture this, its like hazy instead of crystal clear. anyways, if you know how to fix this, tell me quick.
also... i was checking out J-Spec projector lamps and Corksport says that "An additional difficulty arrises from the fact that the integrated corner lense can only accept a single filament bulb. This requires relocating either the turn signal or the parking light. " is this true!?! what do i do then?!
