1 - 8 of 8 Posts
Does anyone know where i can get a headlight lens for my 1993 mazda MX6 cant find anywhere. i have tried fixing mine but they are so yellow.
1992, Mazda MX-6 2.5L V6
If I were in your position I would also try one of those evaporative lens cleaner kits you can get on ebay or aliexpress. I've never tried it myself because I live in a region that has glass lenses but I've seen some good results from using such a kit.
There are several videos on youtube for such things.
Wet sanding is best way I've found so far, as if color sanding paint for paint correction, start with 1,000 grit then 2,000 then 3,000 then finish with a good quality polishing compound, they will look like brand new when finished
Most any of then cleaners work pretty well
I was trying to decide between the 3m and Sylvania. I finally picked the Sylvania because it comes with UV protectant solution. So it should stay nice longer.
1 - 8 of 8 Posts
