I had to replace both low beam headlights and now, they stay on even after I switch them off. Luckily, I have angel eyes so I'm just using the high beam connectors on the low beams until I can figure out this problem. Anyone have any ideas what could be wrong?
I should also mention that the fog lights also stay on as well but I can turn those off by switching the button off. The dash lights, tail lights and parking lights turn off like they should. It's just the low beams and the fogs that don't turn off. Where is the low beam relay located?
There are 2 relays, a stock one, and the angel eyes relay.
The angel eyes one is in the wire harness itself. A small black box with 5 prongs.
You may want to try switching the low beam wire to a Normally open contact instead of a normally closed (pin 86 is NO and 86a is NC)
I do remember someone saying that the relay was used for the high beams though..... Might want to check the stock relay as well. The stock relay is behind the PS headlight i beleive along with 4 other relays.
