Ok so I turn my headlights on and a few seconds later they turn off. All the other dash lights, fog lights, and turn signals still work. I keep turning the knob to make sure there on and after about 10 try's they come back on only to go out again after a few seconds. And after this it keeps taking longer and longer for the headlights to turn on at all. NEED HELP ASAP! Thanks
sounds like teh relatively common steering wheel switch problem.
open up the steering wheel cover and get in there to make sure all your wires are in tact, not frayed, etc... if thats all fine, then its the stalk itself.
also could be a relay under the hood going bad - or bad ground, etc etc.
i would lean towards the stalk on the steering wheel however, since its a fairly common issue (not as common as the rear brakes or distributor, but still common enough)
